Narrow front end AC B
Jody Nusbaumer
04-25-2001 11:09:23
I have an narrow front B allis and wanted to know the production numbers and what it might be worth.
Darrell Jr (MN)
04-28-2001 18:55:19
 Re: narrow front end AC B in reply to Jody Nusbaumer, 04-25-2001 11:09:23
Actually both the B and C were 1 plow tractors, the CA was a 2 plow tractor. The B had the wide front because it was designed for 1 row cultivation, and the C was designed for 2 row cultivation.
steve
04-25-2001 17:24:47
the serial number is stamped by the transmission shift lever on top of case. like the other response said, it is probably a C, the B had wide front because it is made for a single plow setup. The C is a double plow. If it says B and is narrow, you probablly have a combination of parts. To the left of this page is "Serial Number" link that will tell you the year it was made.
WSF
04-25-2001 16:33:05
You probably have a C, not a B. Look at the serial number and I bet it starts with a C.
