B stalled and won't start
lessons learned
D13
04-24-2001 16:12:39
My brother in law was using my Dad's B last winter when it stalled under a load. He got it to restart but then it stalled again and wouldn't crank. It's 6V and he didn't want to use 12v to jump it so he shut it off and left it. This was in February when the weather was wet and just around freezing.
I pulled it out of the field this weekend and checked it over. The battery was flat, so I put the charger on the starter connection and the ground at the tractor. No charge. I pulled the battery cables and put the charger on the battery terminals, it was happy to take a charge. I cleaned the terminals and put it back together, in 15 minutes it started right up. it points out the importance of clean connections for 6V.
He had noted that it wasn't charging, so I set it to high charge, and it registered 15A. Again, clean terminals.
While it was running I noticed the carb had a grey sheen and wet look to it. I pulled the oil cup off the breather and sure enough, grey water/dirt/oil mix was found. I cleaned it off and all was happy. This tractor no longer has the air cleaner cap, the water wasn't a problem until the tractor was used on a wet day. The original stall was caused either by no power to the coil, or the water in the cup freezing with the rush of cold air under wide throttle conditions. Of course, with no cap over the air intake, water would have been a problem sooner than later, and the dirt will always be there.
I must confess this has made a believer in battery cable and air cleaner maintenance out of me. Hopefully someone else can profit without being shut down first.
len fickling
04-24-2001 20:22:18
 Re: B stalled and won't start - lessons learned in reply to D13, 04-24-2001 16:12:39
Hi Just looking for someone that can let me know what the difference is between an A and a B allis Chalmers. Where to look to id the little bugger.
The owner claims it is an A and an old timer claims it is an A also. Since there is so little information about A's I am looking best possible leads.
Thanks for what ever help you might shine on the subject. Len
Rob in MO
04-25-2001 04:53:04
 Re: Re: B stalled and won't start - lessons learned in reply to len fickling, 04-24-2001 20:22:18
An Allis B looks about the same size as a Farmall C. It usually has a wishbone style front end and the serial # in front of the shifter lever will begin with a "B". An Allis A looks more like a tank, sounds like a tank and has more power than a tank. Wide front is not adjustable, had orchard-looking fenders (smooth half circles.) IF it is an A you should get it. They are true collector's items and restored ones often bring BIG $$$
Glenn(WV)
04-25-2001 06:48:00
 Re: Re: Re: B stalled and won't start - lessons learned in reply to Rob in MO, 04-25-2001 04:53:04
Could someone post a picture of an A or direct me to a picture?? I didn't know that A-C built an A.
