WD tsx carb adjustments
Rob
04-24-2001 14:48:17
Can anyone shed some light on the marvel tsx carb adjustments. There is one adjustment on the bottom of the bowl . another on the throttle arm (Im thinkin thats idle ) then one on the top of the carb(spring loaded screw needle type) I just got my new manifold and gasket set and a new needle and seat for the carb. Also when I pulled the old studs out antifreeze ran out of the middle 2 on the block. Is it reccommended to put some type of sealant on the manifold studs prior to installing them??
wdgloff
04-26-2001 18:34:25
 Re: WD tsx carb adjustments in reply to Rob, 04-24-2001 14:48:17
According to the AC manual:main load screw in front, idle mix next to throttle bore, idle speed screw on backside of shaft near engine block. start with idle needle at 1-1/2 turns and main load at 1-3/8 turn. Good luck
