Weight of a WD45 for hauling it.
Rob
04-23-2001 09:33:50
I need to know how much my WD45 weighs. I am buying a trailer and want to know what the load limit should be. Thanks.
GeneD14
04-23-2001 12:17:27
 Re: Weight of a WD45 for hauling it. in reply to Rob, 04-23-2001 09:33:50
If you are buying a trailer it is always better to go a little bigger than you need. New the tractor was around 4500 lbs. If you get wheel weights or load the tires it is easy to add another 1000 lbs or so. Also if you transport it with a plow, mower, blade or other implement it can add alot. If you buy a 7000gvw trailer it is easy to get into an unsafe situation because the trailer weight plus the tractor can easily exceed 7000gvw.
