Matt, First of all, set your point gap to .020 inches with the rub bar of the points on the top of a cam lobe. To set the static timing initially, this is how I do it on my 1950 Model B with distributor: 1. Pull #1 plug wire and remove the plug. 2. Put finger in plug hole and have someone turn the engine with the hand crank until you feel air escaping from hole. This is cylinder #1 compression stroke. 3. Go to left side of tractor and look for a hole in the clutch housing between the two implement mounting bole holes. You should be able to see the flywheel through the hole. 4. Turn the motor very slowly with the hand crank until you see a line engraved on the flywheel that says "Fire". 5. Continue turning the motor for a few more degrees until you see another line engraved "Dead Center". Stop turning the engine with the line in the middle of the hole. 6. Go to the distributor and remove the cap. Make sure that the rotor is pointing toward the position of the #1 plug wire. 7. Loosen the bolts holding down the distributor and rotate the distributor clockwise about 1/8 of a turn. 8. The manual says to rotate the distributor counter-clockwise until the point gap is .001 inches, but since I don't have a feeler gauge that thin, I disconnect the primary ignition wire from the distributor. Then I put the probes of my multimeter on both sides of the points. As soon as the points break, the meter reads infinite resistance so I know that the points are open about .001 inches. 9. Tighten the distributor and you should be close on static timing. 10. Reconnect the primary ignition wire and replace the distributor cap. Replace the #1 plug and wire. Also, something you might replace that is cheap are the points and condenser. Mine started skipping badly a couple of weeks ago. I replaced both of these and it smoothed out completely. NOTE: I have always liked NAPA ignition parts, but found out the other day that the parts numbers for the distributor cap and rotor for the A-C Model B are wrong. Take your old parts with you if you decide to buy NAPA parts. They have the correct parts, only not the ones shown in the catalog. Best of luck. The A-C B is a great little tractor. Don't give up on it. You will learn a lot just in the process of problem solving that will help you in the future.
