No oil pressure AC-C
Randy Waldrip
04-21-2001 20:48:41
Help!
I have a 1947 Allis Model "C". I was running it to move some stuff today, and noticed that I was showing NO OIL PRESSURE! I honestly don't know if this problem developed suddenly or had been dropping slowly - it was good a couple of weeks ago. I dumped my load and parked it as soon as possible. I removed the gage and checked its operation with my air compressor - OK. I removed the line feeding the filter and gage, and ran the engine with the line removed. I got no oil flow, but I could feel some pulsation of air at the fitting. I pulled the pan, cleaned the pick-up screen. I did not remove the down tube, but it seemed like it was quite firmly attached. Pan back on, oil in, still no pressure indicated. Am I missing something? Please send any ideas or experiences that you have had with this problem.
Thanks, Randy
mark dingbaum
04-23-2001 07:19:56
 Re: No oil pressure AC-C in reply to Randy Waldrip, 04-21-2001 20:48:41
The oil pump is driven by a pin the back of the cam. When I overhauled mine recently, the pin was worn almost to the point of failure. If you have to get the pump off, make sure this pin is OK before reassembly.
Good luck,
mark
Dan
04-22-2001 07:24:16
Randy I had a similar problem with my C a few years back. The oil pump had lost it's prime, I took a pump oil can an hooked it up to the oil line by the filter and pumped some 30 W oil back into the pump and like magic had oil pressure when I started her up again. Hope this will work for you, it is worth a try. good luck!
