Getting a steering arm back on a C
JW (MI)
04-21-2001 09:40:21
I'm helping a friend with his C. He pulled the steering arm off the steering box in order to remove and overhaul the steering box. The problem now is that the steering arm won't go on easily. I put anti sieze on the shaft before we tried. There was no corrosion on the arm. Any ideas? Thanks for the help, JW
Tom
04-21-2001 18:08:16
 Re: Getting a steering arm back on a C in reply to JW (MI), 04-21-2001 09:40:21
There could be one spline missing as a way of locating the arm in the right place, check for this.
JW (MI)
04-21-2001 19:54:49
 Re: Re: Getting a steering arm back on a C in reply to Tom, 04-21-2001 18:08:16
We've got it started, just can't get it all the way on... seems to be hung up. Any ideas?????
Tom
04-22-2001 16:52:53
 Re: Re: Re: Getting a steering arm back on a C in reply to JW (MI), 04-21-2001 19:54:49
If it came off it will go back on. Look for the reason. Look at both ends of the splines. Look for that missing spline, I don't know if there is one but many steering boxes have such, as a way of getting the arm back on in the right place. Is there a piece of dirt or something stuck in there that isn't letting it go on all the way? Good luck!! Let us know how it goes.
