'C' oil lines, ferrule source?
mark dingbaum
04-20-2001 10:43:26
Hi,
Mowed with my restored 'C' for the first time last night and I've got a couple oil leaks that just won't stop. The 'T' fitting in the head leaks from the oil lines on each side (pump/governor). They seem to use a cone shaped ferrule on steel line. I've got them as tight as I dare now and they still leak.
Anyone have a source for these ferrule and/or new lines?
thanks
mark
Tyler(WA)
04-20-2001 12:49:39
 Re: 'C' oil lines, ferrule source? in reply to mark dingbaum, 04-20-2001 10:43:26
I don't have a source for you but I do have a caution.
If you're talking about the 'T' that is right after the pump and splits off a smaller line to the head..... be cautious. The oil pump on the "little allis'" is marginal at best. If you enlarge the oil line to the head in hopes of improving upper engine oiling, you will rob the lower end oil pressure and your engine will fail to properly lube the main and rod bearings.
Good luck in your search for those ferrules. Try a line off to Dick L. on this board.
steve
04-20-2001 19:04:51
 Re: Re: 'C' oil lines, ferrule source? in reply to Tyler(WA), 04-20-2001 12:49:39
Go to NAPA or Auto Zone and show them the fittings. These are common on a lot of equipment.
