CA clutch sticks
Don E. Foster
04-19-2001 17:27:43
I have a problem the clutch on my CA sticking when I first start it up. After jerking it around a bit to get it's attention, I seem to have no problem.
What does it need and how much of a problem is it to fix?
Thanks
Steve W
04-20-2001 07:14:44
 Re: CA clutch sticks in reply to Don E. Foster, 04-19-2001 17:27:43
I think it needs to be worked a little harder. Also, block the clutch pedal down if you are gonna let the tractor sit for awhile.
Take Care
Steve
Phil Auten (TX)
04-19-2001 20:58:24
Don,
It needs to be worked. Also, if you can, store it inside. The clutch plate is rusting to the flywheel. A day of working the tractor with a plow or disk will probably fix it until it sits for a long time again. This seems to happen to tractors stored outside or in barns with dirt floors more often than ones stored inside on concrete. I'm not exactly sure why the dirt floor does it and the concrete floor doesen't, but that seems to be the case.
Phil
