WD-45 water in oil
J. C.
04-18-2001 08:31:06
My dad forgot to drain the water out of one of our WD-45's (we have 4). We tried some stop leak, it didn't work. Last Sat. we took the head off, removed the block and the oil pan. No visable damage. Does anyone know the best place to start looking? should we have the head checked or go ahead and remove the pistons & sleeves/
Don Holden
04-18-2001 11:32:10
 Re: WD-45 water in oil in reply to J. C., 04-18-2001 08:31:06
J.C. I have a D17 and I found the same thing when I changed the oil this spring. Antifreeze in the oil. I pulled the head and everything looked good. I was advised to drop the pan and pull the sleeves and replace the "o"rings. Inspection of the old "o"rings revealed that it was great advice because they were SHOT. If you're that far along I would recommend that you replace them. Sandy Lake told me that you can count on the "o"rings being responsible for this problem over 80% of the time when the head gasket & everything else looks good. Good Luck
Don Holden
Tom
04-18-2001 18:02:00
 Re: Re: WD-45 water in oil in reply to Don Holden, 04-18-2001 11:32:10
There is a couple of freeze plugs in the head that could be rusted and leaking, probably not your problem, but worth looking closely at them before pulling the sleeves.
