Rear housing gasket for a 'C'
D. Johnson
04-17-2001 19:28:45
Does anyone know a reliable parts supplier that would have the gasket that goes between the PTO housing and the rear axle housing? I have a sheet of paper gasket I could make one from but I am thinking it is a special gasket material because it looks like it is supposed to separate the oil in the PTO housing from the oil in the rear axle housing, even though there is nothing to support the gasket in this area. I don't know if paper gasket material will hold up. I also need to order a full set of decals. I appreciate any suggestions.
Peter J
04-21-2001 14:28:08
 Re: Rear housing gasket for a 'C' in reply to D. Johnson, 04-17-2001 19:28:45
Made my own from roll gasket material. Been in 10 years. No problems.
Ryan - IN
04-18-2001 06:52:59
Lyle Wacker - Wacker Decals will set you up with the correct decals. ..
David (Al)
04-17-2001 22:17:08
Made one out of valley tin for my B. The manual shows what it looks like. It has a dam to prevent fluid from running to and fro on incline. Used form-a-gasket and is working great.
