WD weight
width - horsepower
scs
04-15-2001 14:38:32
How much does WD weigh with fluid in tires? How wide with rear wheels all the way in? & all the way out? How does WD compare to D17 in horsepower
Dubya Dee
04-17-2001 13:59:15
 Re: WD weight - width - horsepower in reply to scs, 04-15-2001 14:38:32
The wheels on my WD aren't all the way in and it will fit in 76 inches.
Ryan - IN
04-16-2001 06:52:28
30.23 drawbar; 34.63 PTO; max pull 4304lbs; 3388 lbs w/out fluid in tires
width = 56-90inches . . this is rear tread
D-17 Gas
48.64 drawbar; 52.70 PTO; max pull 7059 lbs; 5300 lbs w/out fluid
If mixed properly I think CaCl is 11 lbs/gallon.. .
Above info is from AC Data Book by Terry Dean
Unimog
04-15-2001 19:49:08
The WD weighs in at 4000 lbs. without tire fluid.
The fluid weight will vary based on tire size and
liquid type (water,anti-freeze,calcium)and amount.
The WD has about 35 PTO hp and the D-17 has 15 to
18 more.
Unimog
George
04-15-2001 19:16:10
It may be of some help to try Link There is a profile of the WD with some good stats.
