Gas leaking from carburetor on wd
DONALD
04-13-2001 15:53:00
gas leaks from carburetor when motor is turned off. does not leak when motor is running. ihave to turn valve at the filter bowl to stop gas from leaking. can someone tell me what the fix should be.thanks in advance.
Dave
04-15-2001 14:40:00
 Re: gas leaking from carburetor on wd in reply to DONALD , 04-13-2001 15:53:00
Mine did it and I installed a carb kit, bought from central tractor, cost $29. Started right up with just the presets on the needle valves and runs great.
dave
Aaron
04-13-2001 16:12:16
Sounds like the needle and seat need replaced. Not a huge job. You can get a carb kit and go through it. Also, make sure the float floats when you have it apart.
Aaron
