Allis B
BUNKY
04-12-2001 19:34:28
hello i have a couple of questions????? ?
1 in order to change the brake bands from the original stud type to the newer style bolt type the manual sya that you need to chip out the casting to get the bands in has anyone had to do this mine went right in and my serial number was below what the book said? 2 i have a loose center on my rear wheel i hear this can be expensive to repair about how much for a center? and does the axle usually wear? also my tractor is a 1941 and it had steel wheels is the centers the same? thanks.....
T Seifert
04-12-2001 20:23:32
 Re: allis B in reply to BUNKY, 04-12-2001 19:34:28
The splined stub axel is hard and if the cast iron wheel is even a little bit loose, it will start to wear. B's are prone to this. The cure is to replace both the stub axel and the cast wheel and keep the axel nut tight. The stub axel and cast wheel each cost about $200+ each. There may be other ways to fix this, if there are I'd like to hear about them.
Ted
