6080 Clutch
Greg Ralyea
04-04-2001 09:51:12
Someone help! Have a 6080 in for engine overhaul, discovered it also needs a clutch. Does anyone have either 1) Dimensions so I can make a tool to set finger height on pto and traction clutch levers, or 2) the dimension itself, and describe what point to reference from to make these measurements. Have done many Deere and MF clutches, setting up this way, assuming AC has some means of setting same to allow someone to set one up without having to tear down numerous times. Someone please advise. P.S. Also could use the same spec's for 6060 tractor as i have one coming in next week for a clutch job. In advance, thank you, all. Greg
John Taber
06-08-2002 18:55:47
 Re: 6080 Clutch in reply to Greg Ralyea, 04-04-2001 09:51:12
So, out of curiosity, was anyone able to help you?I just a 6080 dropped in my lap for a slipping clutch. It is original, and I was going to split it and do the job. There is no tech manual available for me, so I am searching the net looking for a little info. Any help would be appreciated. Thanks....
Kraig
06-15-2003 20:39:38
 Re: Re: 6080 Clutch in reply to John Taber, 06-08-2002 18:55:47
I got a paper in the new clutch with dimensions on it and just did as they said. I used the tool before a local dealer may let you rent it or use it.
Kraig
11-04-2003 22:28:56
 Re: Re: Re: 6080 Clutch in reply to Kraig, 06-15-2003 20:39:38
You can take your flywheel off, take it to a dealer and have them use the tool to set it up on the bench and take it home put it on it will be all set. Some dealers have a plate they bolt them to to set em up, u won't need to bring the flywheel, or just borrow the tool. I just did a 5050 clutch and borrowed a tool, if u could that would be the way to go.
