Wd45 hydraulics not working
mark anthony sv
03-26-2001 09:57:03
My wd45 hydraulics don't work properly. They don't respond right away or not at all. Can't lift my mower.Any ideas?
David Thomas (MO)
03-27-2001 06:55:59
 Re: wd45 hydraulics not working in reply to mark anthony svetlik, 03-26-2001 09:57:03
That's not much information to go on. How does the lift perform without any load? Check the oil level first and make sure it has no water in it. If that checks out OK, you may have air trapped in the rams. If you still have problems after bleeding the system you may have sticking pistons in the pump or a weak/broken unloading valve in which case you'll have to pull the pump and either rebuild it or buy a rebuilt (~$275).
David
Mark Anthony .Co.
03-27-2001 09:18:14
 Re: Re: wd45 hydraulics not working in reply to David Thomas (MO), 03-27-2001 06:55:59
Thanks Dave for the information, i appreicate it. My wd lift arms will come up automatically on occasion, and when I press down on the control lever, the lift arms don't go down. I have to bleed the rams inorder to sink my attached impliment, such as a 6'rotor mower.
David Thomas (MO)
03-30-2001 14:22:19
 Re: Re: Re: wd45 hydraulics not working in reply to Mark Anthony .Co., 03-27-2001 09:18:14
Been there. Sounds like a broken or stuck control valve return spring (also called a backup spring). When the lift control is moved to the "raise" position an internal cam in the pump turns in to "push" the control valves forward allowing oil to pump into the rams. When the control is moved back to the hold or lower position a backup spring is suppose to push the control valves back to the bypass position.
Another possibility is that someone has opened the pump at sometime and installed these control valves (four of them in a line) backwards.
Either way its a relatively easy fix (if that's all that's wrong with it and you can find replacements for broken parts) *once* you get the pump off the tractor. The first time you do one is quite a learning experience. Depending on why the control valves are sticking it way be worth your time just to buy a rebuilt pump (~$275) as you can sink a lot of time in one since the only way you (and I) have to test it is to put it back on the tractor (another learning experience BTW).
The good news is that once you get the knack you can yank the pump off, make your next "adjustment" and slap it back on the tractor in under 30 minutes. Do that five or six times and you're a pump pro.
Get the pump off the tractor and I'll step you through the disassembly process. If you decide to tackle it yourself and have a digital camera, take lots of pictures and maybe we'll submit an article to ytmag on this style of pump. (If there's one in the archive, I couldn't find it.)
David
Tom
03-30-2001 18:26:49
 Re: Re: Re: Re: wd45 hydraulics not working in reply to David Thomas (MO), 03-30-2001 14:22:19
You can get a reprint of the AC Service Manual for WD& WD 45 from King's Books for $12.95. They also have an owners manual. And a lot of other tractor books. Good quality on the manual tht I have, and a good section on the pump. King's is at P.O. Box 86 Radnor, Ohio 43066-0086. $2.00 shipping and handling per order no matter how many books you order.
Tom
