CA Horse Power/Mower Capability
J.K. Clark
03-26-2001 04:56:06
Can someone tell me what the horse power of a 1949 CA would be, and what size/type of pull type rotary mower it can comfortably handle? The tractor does NOT have a 3 pt hitch and we do pull on some MILD inclines. Thanks.
Tyler(WA)
03-29-2001 10:15:59
 Re: CA Horse Power/Mower Capability in reply to J.K. Clark, 03-26-2001 04:56:06
If you're worried about h.p., why not consider the self powered pull behind mowers?
JR
03-28-2001 12:03:28
Thr horsepower is 24 drawbar and 27 PTO. It depends on how thick the field is that you are cutting but you should be fine with a 5 foot. I wouldn't go any bigger. I don't see many 4 foot pull behinds out there.
Nick
03-27-2001 13:13:28
I have a 72" woods belly mower on my 52 CA. I don't have any problem finish mowing in 3rd gear.
Dan
03-27-2001 09:45:20
Best check you serial # beside gear shift and see what you have for sure. I believe CA's started in l950 with only a few. Check serial # on this site under Research and Info. Also check the article "The Little AC's." It describes a lot about C's and CA's. Belly mower would be best for this tractor (B's, C's and CA's) I think.
Ted
04-01-2001 19:37:42
 Re: Re: CA Horse Power/Mower Capability in reply to Dan, 03-27-2001 09:45:20
I have a 1955 CA and pull a woods XT60 (60 inch) mower behind it to cut my field. Never had a problem yet or lacked sufficient power for the mower. CT Central Tractor Stores sell both pull behind and three point hitch type mowers. Mine is the three point hitch type.
