D14 Starter Removal
Chris Heiden
03-25-2001 13:32:25
Hey guys help. I have removed the solenoid but can't get the starter removed. I have removed the one bolt for the starter. Any help here? Specs: 1960 AC D14 12 volt starter Delco Remy Thanks, Chris
Mike M (RI)
03-25-2001 15:03:37
 Re: D14 Starter Removal in reply to Chris Heiden, 03-25-2001 13:32:25
Hi Chris,
I gave a little push with a pry-bar or large screwdriver...while at the same time I grabbed the starter motor with my hand and gave it a wiggle. It came right out, but was rusty where the nose contacts the engine. Maybe you can get some wd40 in that area. Is it possible starter drive is engaged into flywheel? Maybe turning engine by hand will free drive loose if it is hanging up.
