Clutch Lubrication
D13
03-24-2001 04:29:39
I'm redoing my clutch on my B and question the appropriate lubes. What do I use on the shaft splines to clutch disc? There appears to be grease on the old one. How about the pins and arms on the pressure plate? These appear to be dry on the old one. Between the arms and the throwout bearing? The bearing and throwout collar are both greased. How about the threaded rod, fork, and throwout collar surfaces?
I'm leary of using silicone because silicone on a clutch is a slippery mess. I'm concerned about grease and oil due to clutch dust and dirt building up and accelerating wear. I do have the clutch apart so applying correct amounts in correct locations is not a problem.
Any and all direction is appreciated.
peterc
03-25-2001 18:26:49
 Re: Clutch Lubrication in reply to D13, 03-24-2001 04:29:39
if it has a grease zerk use general purpose grease if it dosen't have a grease zerk it doesn't need to be greased.
