Unsticking Valve
Rick in NC
03-23-2001 05:04:09
Like Barry below, I think that I have a stuck valve on my 1950 B, because it was running great last week. I started it this week and it run really rough. I think that it may be a stuck exhaust valve because it seems to pop out of the muffler instead of through the breather.
If I take off the valve cover and find a stuck valve(s), what is the best way to unstick them and keep them unstuck?
This same thing happened last Spring, but it seemed to cure itself. The tractor ran fine all Summer and Fall, but has started again this Spring. I didn't know that tractors could contract Spring Fever, but I guess that mine has it.
Thanks for any help.
FARMER BRADLEY
03-27-2001 05:29:34
 Re: Unsticking Valve in reply to Rick in NC, 03-23-2001 05:04:09
IF THIS STUCK VALVE PROBLEM KEEPS OCCURING PUT A COUPLE OF OUNCES OF MARVEL MYSTERY OIL IN EACH TANK OF FUEL. THIS WILL LUBRICATE THE VALVE GUIDE AND SEAL. HOPEFULLY THIS WILL CURE YOUR PROBLEM. GOOD LUCK!!
FARMER BRADLEY
03-27-2001 05:28:25
FARMER BRADLEY
03-27-2001 05:27:10
D13
03-24-2001 04:04:13
The valves started sticking on my B in the middle of summer. It also was the exhaust - all that heat. I found that the exhaust rockers had been replaced with intake rockers which limit the oil supply to the valves. Without proper lube the rockers wore at the valves and the valves got hot and seized.
Farmer-Gene
03-23-2001 09:04:49
When I was a kid on the farm working with my dad we had WC's and JD A's and whenever they started acting up dad said better put that one on the plow and work the heck out of it. The trouble now days they just get started to hear them run and mostly idle so tend to get carboned up so after you get it cleaned up you might want to work it once in awhile.
Dick L
03-23-2001 06:41:02
If you actually have a stuck valve and it was me, I would take the head off and find the reason. It could be several things but rust and crud on the valve stems or bad valve guides hit the top of my guess.
