WD45
Jerry Elam
03-22-2001 18:03:45
I have a chance to buy a '35 WD45 for $2,200.00. It has a repaired crack in the water jacket of the engine that supposedly has held for a long time. I would figure on replacing it if I buy the tractor.
Does this sound like a good deal?
Jerry
roger
03-23-2001 18:41:57
 Re: WD45 in reply to Jerry Elam, 03-22-2001 18:03:45
i agree with john at that kind of price it should have a wide front end(factory..which would be square tube..not round),good paint tinwork and tires. i never trust a cracked block unless its just an outside crack, not on the inside. if you plan on replacing the motor anyway then you will have way more money in it than it is worth around most places. i live in central mo. and can buy wd's and wd45's from 400 dollars on up..guess it depends on the market in your area and how badly you want the tractor...sincerely roger
Jerry Elam
03-22-2001 18:54:45
I ment '53,my dyslexia is acting up again
Thanks,
Jerry
Tom
03-22-2001 18:10:58
If it is nice and runs good that is probably a fair price, don't worry about the crack. Is it near the drain plug in the block on the left side, they often crack here, run front to back.
John (C-IL)
03-22-2001 18:10:43
That is probably a one of a kind tractor as WD45 production began in late 1953. Around here $1500 will usually get you a decent WD45 the really good ones, tires, tin, paint and operation will bring from there to about $2500. John
