Plows for a B
Matt
03-22-2001 06:45:19
Did the plow for a B mount between the wheels? Also, did it hook up to the hyrdraulics? I've noticed there are some bolt holes in the torque tube/transmission housing, and figure they must be there for something.
Also, is it possible to mount a chisel type plow to a B?
Since I don't have all the hydraulic parts I need, has anyone out there fabricated their own manual raising/lowering plow or blade, etc.....
Lots of questions I know, but just got this B and am trying to learn.
Thanks, Matt (Ohio)
Darrell Jr (MN)
03-23-2001 11:22:39
 Re: Plows for a B in reply to Matt, 03-22-2001 06:45:19
Matt, If you mean between the front and rear wheels, no. The plow mounts, as Tom said, to a bracket that is between the final drives, but actually sticks out the rear of the tractor, and hangs by a bracket mounted to the rear of the seat frame. The holes in the torque tube are for mounting a cultivator. Getting back to the plow, they made left and right hand plows, and you could have 1 of either, or both(Two way- one bottom). They could be bought with either hand lift, or hydrualic lift. If you are looking for one, there is a guy in MD that has 2 one bottom plows, 1 hand lift and 1 hydrualic, with all the brackets to mount them. He has the lift cylinders also, if you need one of them too. E-mail me and I'll get you name and number. Hope this helps, Darrell Jr (MN)
tom davison
03-22-2001 14:50:15
The plows for a B mount under the tractor. The plows have a special drawbar that is made for pulling the plows. The drawbar hooks to brackets that are made for this drawbar. They mount in the holes in the final drive housings. These holes are in front of the holes used to mount the regular drawbar.
It is possible to make anything, but it would be difficult to make a lifting mechanism for the plows unless you had an original for a guide.
There were hand lifts for these plows, as well as hydraulic lifts. I don't believe that you want the hand lift.
A chisel plow could be hooked to the B, if you had the right hardware to do it.
steve
03-22-2001 20:26:23
 Re: Re: Plows for a B in reply to tom davison, 03-22-2001 14:50:15
do you have the hydraulic pump, valve mounted on the right side of the differential under the seat? if so you might be able to add the small cylinder for a lift. YOu normally see a rod with an eyelet sticking up by the seat cushion on right side, if you have hydraulics. What year?
Matt
03-26-2001 07:31:55
 Re: Re: Re: Plows for a B in reply to steve, 03-22-2001 20:26:23
I have the pump and eyelet lever you speak of. But, that's it. I saw mention of different types of cylinders (hi and low compression?) on this forum. AC used hi? It sounded like low style wouldn't work quite right, but anyway, I'm ahead of myself. Looks like I would need to purchase the rest of the hydraulic parts in order to use AC implements.
steve
03-27-2001 18:40:27
 Re: Re: Re: Re: Plows for a B in reply to Matt, 03-26-2001 07:31:55
if you have the lever with the eye, and the pump is kind of hid inside. you can see the valve on the differential case (pto). There should be a 1/4 inch pipe plug on the valve. this is where the hose came off. pull the plug and install a small hose and put in bucket. bump the eye rod at low idle and oil should drool out the hose. you can get about 3000 psi on this system, but low volume. a good 1 inch or 1.5 inch bore cylinder will do a good job.
