WC Hollow bolt
Ric Wells
03-21-2001 18:53:58
I removed the rear hub cover and the hub. I removed the round hub cover back plate. Everything was covered with 65 year old grease. Cleaning the bolts that holds the plate to the rear axle housing,I found one bolt that has a hole thur it and do not know where it was installed. Looks like it might supply axle grease to the gears.
Jim Smith
03-22-2001 19:44:31
 Re: WC Hollow bolt in reply to Ric Wells, 03-21-2001 18:53:58
The bolt you are refering to is a beather between the closed chambers of the rear axle. If the hollow bolt was not there, there would be grease on the garage floor after a good day of work. Per my 1935 manual, and I checked with Motors Manual -- the hollow bolt goes in the front of the pinion gear. Meaning same plane as gear but toward front of tractor.
