D-17 Hydraulic Problems
Mark
03-21-2001 18:11:38
My 3 pt would not lift in cold weather. Now I checked the Hyd level and it was low. I put in 2 gals and found that it is somehow going into the transmission. Any ideas what tube or internal part might have broke? Thanks
Don Holden
03-21-2001 19:05:10
 Re: D-17 Hydraulic Problems in reply to Mark, 03-21-2001 18:11:38
Mark, I just finished a repair on my D17 with the same symptons that your tractor exhibits. My tractor had a bad hose that supplies hydraulic oil to the lift arms resulting in the transfer of hydraulic oil to the transmission, similar to what you are finding. I purchased a new hose and ram packing along with the required gaskets from Sandy Lake Implement and it fixed the old girl right up. He will supply the parts and if you need help advice! Oh, by the way, it helps if you have a repair manual to walk you thru process.
Good Luck on the Fix
Don Holden
