Snap Coupler Latches
Crawlerjohn
03-20-2001 04:41:21
I got some latches in a bucket of junk at auction Sat. They are steel not cast but fit on my WD arms. I was wondering if they were factory or aftermarket replacement parts. They look like a mousetrap. Thanks for info, Crawlerjohn
Brian G. NY
03-20-2001 16:57:30
 Re: Snap Coupler Latches in reply to Crawlerjohn, 03-20-2001 04:41:21
The steel ones are the first version. I have three different styles to fit my WD & WD-45. The other two styles are cast. I have heard that there are as many as 4 versions.
LARRY
12-02-2002 07:13:43
 Re: Re: Snap Coupler Latches in reply to Brian G. NY, 03-20-2001 16:57:30
WHERE CAN YOU BUY THESE?
John (C-IL)
03-20-2001 16:24:59
Around here used ones with good springs are $50 per pair, You can buy new ones I am told for $100 per pair. john
JERRY
03-20-2001 16:15:10
THE EARLY LATCHES HAD AN OPEN TOP. NOT SOLID LIKE THE LATER ONES. AROUND HERE THEY ARE GETTING SCARCE AND I KNOW OF SOME PRICED AT $5O APIECE!
LARRY
12-02-2002 07:11:50
 Re: Re: Snap Coupler Latches in reply to JERRY, 03-20-2001 16:15:10
WHERE CAN YOU BUY THESES?
boman
03-30-2001 03:17:12
noticed comment about open latches. my d14 has open latches (cast)with a spring to help hold them closed. narrow front, 4 speed with h/l. any clue as to what year it is?
