CA hydralics, up but no down
DAN W. COUTOLOE
03-19-2001 18:49:02
Just mounted a front end loader after looking for one for over a year. 2 rams, can fill them with fluid, but can figure out how to lower the arms, fluid wont flow back into system. doing something wrong, but at this point cant figure it out. any help please: Dan
steve
03-20-2001 17:34:07
 Re: CA hydralics, up but no down in reply to DAN W. COUTOLOENC, 03-19-2001 18:49:02
HOw is the system setup. Do you have a front mounted pump and a single valve, with one hose to each cylinder, with the top end of the cylinder vented? Siingle acting cylinders and valve would send oil to the cylinder when valve is stroked. When valve is let go it returns to hold position. Pushing valve the other way makes the cylinder oil drain back thru the single hose, thru the valve to the oil tank. Power up, float down. If it dont float, your valve may not be for a single acting system. Were all parts purchased as a unit from another tractor? Valve should have pressure supply hose, one back to the tank, and one to the cylinders. What does yours look like?
