AC200 Gears
Mike-M
03-19-2001 11:20:21
Does anyone know if the 200s have the same problem as the 1XX series tractors popping out of gear?
Thanks,
Mike
Darrell Jr. (MN)
03-20-2001 15:22:56
 Re: AC200 Gears in reply to Mike-M, 03-19-2001 11:20:21
Mike, when we rebuilt the trans on our '67 190 XT gas, we found used gears from a 200. They were all the same numbers and it works fine now. They're were a few subtle differences, but basically the same trans. BTW, our 190 has the updated rear end with the 4 pinion differential an larger diameter axles. Darrell
tbran
03-19-2001 19:27:33
I posted on UnoffAllis site an extensive, too long of a rambling expose' on this subject. ckitoutifinterested
Jeff
03-19-2001 15:17:31
yup same problem
Mike-M
03-19-2001 17:43:23
 Re: Re: AC200 Gears in reply to Jeff, 03-19-2001 15:17:31
You're kidding. Didn't they ever get that figured out?
-Mike
Glenn
03-19-2001 19:42:46
 Re: Re: Re: AC200 Gears in reply to Mike-M, 03-19-2001 17:43:23
I was under the impression that A-C got that problem licked with the introduction of the 190XT Series III machines. I could be wrong, though.
Jeff
03-20-2001 05:26:55
 Re: Re: Re: Re: AC200 Gears in reply to Glenn, 03-19-2001 19:42:46
7000 series is when it was fixed
Jim
03-20-2001 07:22:16
 Re: Re: Re: Re: Re: AC200 Gears in reply to Jeff, 03-20-2001 05:26:55
I have a neighbor who had a 7000 and the reverse idler kept going out. He finally traded it for a bi-directional Ford. Around here a 7000 has poor resale value because of transmission trouble.
Glenn: Thanks
03-20-2001 05:35:53
Ok. Thanks for correcting me.
Jeff
03-19-2001 18:38:04
190XT and a 200 are about the same tractor with some changes. I saw a 200 at a sale last fall, popped out of 3rd and 4t
Jeff
03-19-2001 18:38:01
