Allis Chalmers WD45 Serial Number
Dan Kacmarcik
03-18-2001 19:51:35
I've seen replys saying the s/n is on the left brake housing. Others say it's on the left side of the differential. Which is it? To me, the brake housing is at the center part of the wheel, on the inside. Is that correct? The differential is the section between the left & right axles. Not the axles themselves. I see nothing in either location. I'm assuming the left side is based on when your sitting in the seat, not standing in front of it.
Brian G. NY
03-19-2001 05:32:12
 Re: Allis Chalmers WD45 Serial Number in reply to Dan Kacmarcik, 03-18-2001 19:51:35
The serial # is on the rear LH side of differential housing, which, by the way is also the brake "housing". The plates that cover the brakes are bolted to the top of this housing, the RH one also serves as the seat hinge. Anyway, you will find the ser.# on the vertical surface of the housing right between the LH brake spring hole and the brake adjusting bolt/locknut. The number is stamped into a flat machined area and may have become filled with paint or other accumulated crud over the years. A wire brush and a little carb cleaner cleans it up real nice. The number will be prefixed with the letters WD. You're correct, the LH side orientation of any vehicle is the same as the left side of yourself. The engine serial number is located on the LH side of the engine, just under the hose leading from the air cleaner to the carburetor and will be prefixed with 45 on a WD-45 or WD on a WD. If you find both of these numbers, would you post them? I have been compiling a list of tractor and engine ser. #s in an effort to get some idea of the relationship between the two. There is not a direct relationship in these numbers as, from what I understand, the engine numbers were consecutive whether the engine was used in a tractor, combine, grader or as a stationary "power unit". Thanks,
Tom
03-19-2001 17:32:44
 Re: Re: Allis Chalmers WD45 Serial Number in reply to Brian G. NY, 03-19-2001 05:32:12
Have a WD, no is WD77470, engine is 284534PA
Brian G. NY
03-19-2001 19:55:46
 Re: Re: Re: Allis Chalmers WD45 Serial Number in reply to Tom, 03-19-2001 17:32:44
Tom, Thanks. Brian G.
