Hand clutch removal
kwges
03-17-2001 15:27:17
what is the proper way to remove thehand clutch assymbly?
Dave Kolby
03-17-2001 16:39:43
 Re: hand clutch removal in reply to kwges, 03-17-2001 15:27:17
It's not complicated but you do need the manuals.
Dave
kwges
03-17-2001 17:45:51
 Re: Re: hand clutch removal in reply to Dave Kolby, 03-17-2001 16:39:43
i will get a maual as soon as possible, however i need the tractor this week end, i need to know if i have to split the tractor and if so ,where do i split it at?
kwges
03-18-2001 07:11:41
 Re: Re: Re: hand clutch removal in reply to kwges, 03-17-2001 17:45:51
tom, thanks for the info, and i sure would appreciate, if you could look in your manual,and tell me where to break the tractor apart, thanks, kwges
Tom
03-18-2001 08:12:41
 Re: Re: Re: Re: hand clutch removal in reply to kwges, 03-18-2001 07:11:41
OK,
Seperate the transmission from the clutch housing.
Now I quote "With the torque tube housing removed from the tractor, remove the four nuts and locks attaching the clutch to the flang of the PTO drive gear. With the clutch engaged the complete clutch assembly can be removed from housing. to completely disassemble remove the six capscrews holding the back plate assembly to the front plate, remove the three shim pads, then install three of the six capscrews removeed and thghten, withclutch engaged, this will compress the pressure washer retainer against the back plate and allow the removal of the large snap ring. With snap ring removed, remove capscrews holding back plate aned front plate together. Remove shifter collar this collar is machined on one side to edentify proper assembly of the two halves. The back plate assembly can now be lifted fron clutch assembly, and pressure washer removed. renmove pressure plate assembly, remove linkage and shifter,remove the three pressure plate retracting springs, remove the center plate and dreve disc assemblies. "
There may be some typos, I was reading and typing. If you need any info on inspection or assembly let me know. there is some info there that you might need or want. I am short of time now but tonight I will have more.
Tom
kwges
03-18-2001 16:48:40
 Re: Re: Re: Re: Re: hand clutch removal in reply to Tom, 03-18-2001 08:12:41
tom, thanks so very much, have the clutch out, all the rivits were shelled,will try to rivit them back, clutch still looks good,thanks again,kwges.
Tom
03-18-2001 18:09:48
 Re: Re: Re: Re: Re: Re: hand clutch removal in reply to kwges, 03-18-2001 16:48:40
Assembly
Install the pressure plate with the small diameter forward, the heavier pressure washeris identified by a red paint mark. Install the front driven disc with the long hub forwaard, and the rear driven disc with the long hub to the rear. The pressure plate retracting springs musn not be kinked, and diring assembly notice that they are properly seated at each end. In case of a three disc clutch the center driven disc has hub with equal lingth on each side. Install shifter collar to shifter with the machined side of the two halves together, this will properly line up inner groove. To properly adjust clutch with clutch rimoved from tractor proceed as follows. Remove capscrews, large snap ring, pressure washer, and the three prsssure plate retracting sprintgs. Build up three shim packs to a thickness of .140". Place these shim packs in place of the pressure washer. Space evenly at 120 degrees apart. Stack the clutch parts together as in regular assembly but with out shims or capscrews.Press the clutch together as ttight as possible by hand, measure the clearance between the front and back plate for shims, subtract .005 from this measurement and use a shim pack of this dimension. Mark tjhe front and back plate and install the measured shim pack in this positiononly, as the three shim packs may be of unequal thickness. Install the springs and the pressure washer (after removing the .140" shsism packs) and the snap ring, assemble clutch and check the disengaged, clearance between the plates, this should not be less than .030". The clutch assembly must be engaged before installing in torque tube housing. Enter studs through drive gear flange and install locks and nuts, Properly tighten nuts to 35 ft. lbs. Tighten setscrew in shifter fork to 45 ft. lbs. Disengage clutch and install the splined shaft by hand, lining up splined hubs with shaft, leave splined shaft installid in torque tube housing, this will aid in installingtransmission to torque tube housing, and eliminate the possibility of damage to the driven disc assemblies. Always keep clutch engaged in cold weather, or when tractor is not in use, this will keep oil out of between clutch plates, and help to prevent clutch from dragging when engine is first started. To adjust clutch with clutch in tractor. Remove ou add shims as required to obtain .065 cleaarance between clutch plates, with clutch disentgaged, adjust shim packs accodingly to maintain an equal clearance all around clutch. Effective with WD-45 165036 a three disc clutch is used.
Tom
03-17-2001 19:36:49
You need to take the cover off the top of the clutch. If it is slipping you may be able to remove shims evenly from the 3 pairs of bolts that hold the clutch together. If there are no more shims you are right, remove it. unbolt the four bolts at the front of the clutch that hold it to the flange of the gear there. Split the tractor, but I can't remember if it is at the front or rear of the clutch housing. I can check my manual tomorrow if noone else has gotten back to you by then. Check for shims though, there should be some that measure in thousands, not the about 1/8 spacers.
