WD MOTOR
John or Brian
03-15-2001 20:26:45
does anybody have any information that they could tell me about what you can do to a 1950 WD Allis to make it compete in the division 3 or 4 pulling classes. any info at all would be much appreciated. Thanks Brian and John (Allis pullers)
Mike B
03-16-2001 03:01:54
 Re: WD MOTOR in reply to John or Brian, 03-15-2001 20:26:45
For div.3you can bore the sleeves & use a 45 crank But to run div, 4 you will need to bore the block for bigger sleeves and have the crank stroked. Port your head & put in bigger valves and use a 45 carb. in either case. Use 15.5x38" tires. This should get you started.
