WD Hydraulics
Jim Tanner
03-13-2001 21:19:20
I have a 1951 WD and it has only 1 ram ,is that the way thay came? And the ram is leaking some, is it hard to repack or should I just look to replace it, and if I replace it does it have to be with the same type ram or can I replace with any companies ram?
David Thomas (MO)
03-14-2001 08:34:02
 Re: WD Hydraulics in reply to Jim Tanner, 03-13-2001 21:19:20
I believe that the WDs usually came with two rams. The ram on the driver's left could be turned to the front of the tractor for use with a front loader while still allowing the right ram to work the rear lift (not to mention a remote line that allowed implements hydraulic power). I've found a source of used rams for about $50 at a local tractor junkyard.
The rams aren't hard to repack but try tightening the packing nut a bit first (assuming that's where most leaks occur). Try a quarter turn and see if that stops the leak. If not, try another quarter turn. If you decide to replace the ram (can't think of any reason why you'd want to as they're pretty much indestructible assuming you haven't blown the nut off like I did recently on my WD45, $3.50 for a new nut and a little work to free up the relief valve {would you believe rust in a "new" rebuilt pump?} and she's back in business) be aware that the WDs have a high pressure/low volume hydraulic system. The upper operating pressure is just under 4000 psi and the system capacity is only 6 quarts (modern hydraulics usually operate under 2000 psi with a few gallons of oil). I believe the manuals warn you not to exceed 40 cu.in. in ram volume when replacing with non-AC equipment.
Another thing to keep in mind is that this is not a "flow through" hydraulic system. Every drop of oil that the pump pushes out into a ram must return through the same hose back through the pump when the ram retracts (usually by gravity) unless you decide to use one of the "work arounds" discussed in this group. Most use one or more of the following schemes; add an oil return line to the hydraulic fill port, set the original pump control in full lift while operating the equipment with an auxiliary "flow through" type control valve, add capacity to the oil reservoir with an additional oil tank mounted on the frame and connected to the original reservoir through the drain plug.
Good luck!
David
Brian G. NY
03-14-2001 19:23:07
 Re: Re: WD Hydraulics in reply to David Thomas (MO), 03-14-2001 08:34:02
Dave, That's a new one; turning the left ram around to power a loader. I don't think it would lift much and certainly not very high. What would be used to isolate the rear ram from the "loader" ram? I installed a 2-way valve on my WD to isolate the rear rams (with the backblade) from the front loader. Works real good for snow removal. Move the bulk with the 6' bucket and do the "clean-up" with the 6' blade.
David Thomas (MO)
03-15-2001 06:09:12
 Re: Re: Re: WD Hydraulics in reply to Brian G. NY, 03-14-2001 19:23:07
Personally I agree, however that is what is stated in the AC user manual. The left ram is "isolated" from the right by the hold position check valve. The left ram is in front of this check valve while the right ram is behind it. The sping tension on this check valve is adjustable (control "C", sometimes called the delay lift control). To increase the delay, turn "C" in. Decrease the delay by turning "C" out. With "C" out all the way to its stop, I think the book says it takes about 1000 psi to unseat the check ball. If you attempt to pick up a heavy load using the front loader you may see the rear lift raise (right ram) before the front loader (left ram) moves at all since the two are not truely isolated at all (unless turning "C" in all the way pins the hold position check ball to its seat by compressing the spring completely(?), I don't know), and you do reduce your load lifting ability on the rear lift by half.
David
Brian G. NY
03-15-2001 08:12:32
 Re: Re: Re: Re: WD Hydraulics in reply to David Thomas (MO), 03-15-2001 06:09:12
Dave, I never looked at that piece in the manual before. I think they are talking about front and rear cultivators rather than a loader. The "delayed lift" would keep the rear cultivators in the ground 'til the end of the row.
David Thomas (MO)
03-16-2001 06:55:40
 Re: Re: Re: Re: Re: WD Hydraulics in reply to Brian G. NY, 03-15-2001 08:12:32
That sounds right. I only skimmed the section myself when I was troubleshooting my hydraulic pump. S'what I get for relying on my memory.
