AllCrop drill grass seeder tubes
Dave Grubb
03-13-2001 13:22:01
I have found a source for tubing that will screw into the lower wire tubing supports used on the drill. It is available from Canal Rubber Supply Co..Phone 1-800-4446483. It is called light duty equipment OEM tubing. It is $.90/ft. I used 26" lengths on each row. I had to use a 1/2" to 1" copper tubing reducer cotter pinned to the seed case and slipped the 3/4" I.D. tubing onto it. It looks like a factory setup and works well. I sowed 10 lbs. of grass seed Sunday and have 30 acres of alfalpha and oats to sow this week.
