D14 Starter question
Chris Heiden
03-11-2001 11:46:48
Greetings, Today was a beautiful day here in Michigan until . . . I tried to get my 1960 D14 started. It turned over several times and stalled (which is in its character). However, upon giving it a while to rest and restart it I noticed a clicking everytime I tried to turn it over. I checked the battery (one year old) and it was fully charged and I tried to jump start it. No success. My theory is it is the starter because of the clicking. What do you all think?
-- Chris Heiden
Mike M (RI)
03-11-2001 16:21:11
 Re: D14 Starter question in reply to Chris Heiden, 03-11-2001 11:46:48
Chris,
I also have a '59 D14 that used to crank over very slowly...until one day last summer, while trying to start it, the engine "kicked" and broke the nose of the starter...which jambed the drive into the ring gear. The engine was stuck...causing the solenoid to click like crazy. I found a used replacement nose for starter & converted tractor to 12 volt system. Starts instantly now. Just my 2 cents worth.
Mike M (RI)
03-11-2001 16:19:03
Chris,
steve
03-11-2001 11:57:16
how about checking the terminals on the battery and the cable ends to the starter and solenoid for corrosion or winter crud. If o.k. then starter (or solenoid)is a good bet. Click could be the soleniod pulling in , but bad internal contacts? Might try jumping a spare battery straight to the starter and eliminating your cables for a test.
