WD guages.....available through aftermarket?
ernie
03-09-2001 16:14:46
I forgot to add this to my prior post. Does anyone out there know if the water preesure guage attatched to the radiator and the oil pressure guage are available through an aftermarket company? Mine are looking a little nasty and I really want to keep this thing as original as possible. Thank you all in advance for your generosity. Doc, no need to respond buddie!
Sandy Lake Implement
03-11-2001 13:22:39
 Re: WD guages.....available through aftermarket? in reply to ernie, 03-09-2001 16:14:46
We stock both the OEM named temp guage and the aftermarket with no name. OEM is roughly double $
of the no name. We also stock the named oil guage.
Bill from home
PAjeff
03-11-2001 11:37:05
I am a new wannabe to this site & haven't figured out how to start a new post. The closes't I get to an antique tractor is my 1976 PowerKing. Does anyone have an opinion on the 51 WD-40 currently on E-Bay? I got outbid on it at $1000. How high should I go?
steve
03-11-2001 11:52:28
 Re: Re: WD guages.....available through aftermarket? in reply to PAjeff, 03-11-2001 11:37:05
You probably mean WD-45, but those were not built untill '53 I believe. Prior to that they were called just WD. Any way they are good tractors. $1000. is in the ball park. More or less determined by how good it looks and runs. To post a new message go to the bottom of the previous page that lists the posts instead of posting a followup to another question. If you just want a small tractor to play around alittle and get into the AC line, you may want to look for a "B" or "C", they are about 2/3 the size of the WD.
PAjeff
03-11-2001 17:57:10
 Re: Re: Re: WD guages.....available through aftermarket? in reply to steve, 03-11-2001 11:52:28
Thanks for the help, steve. I think I can count on you guys for help from what I've read the past several months.
RJB
03-11-2001 00:15:07
Ernie, you should watch out for cheaper gauges!!
If you are going with the orignal look then I would go threw a Allis dealer, the reason I say this is because most of the cheaper gauges do NOT have the words Allis-Chalmers printed in them. That is how they get by with them being cheaper. It all depends on how oringal you want it to look. Myself I pay for the more expensive ones, I am really picky when I am restoring one. But that is just my 2 cent.
Hope this helps.
ernie
03-11-2001 17:42:48
 Re: Re: WD guages.....available through aftermarket? in reply to Aaron, 03-09-2001 16:56:26
Thank you all for your quick responses. I have really enjoyed this site...and learned a few things too!
