Allis B distributor
Paul from Michi
03-06-2001 19:41:22
My old B has been a little hard to start lately, and kind of acts like the timing is too far advanced. Timing checks right on with a light. I pulled the distributor cap thinking I had a stuck advance mechanism. Advance seems quite free, but it doesn't spring back positively when I release it. Should it return from spring tension when the rotor is advanced manually? Could I have broken spring? How hard is it to replace? Let me know what you think. Thanks, Paul
Sandy Lake Implement
03-06-2001 19:56:53
 Re: Allis B distributor in reply to Paul from Michigan, 03-06-2001 19:41:22
Yes it should spring back freely. Perhaps you
are getting some binding at the top of the dist. shaft. Remove your points plate & you can inspect the components of the advance. Static timing should be right on the "CENTER" mark. Bill
