Allis engine- Dick L?
Bus Driver
03-06-2001 09:51:03
I have never worked on an Allis engine internally and wondered about what I am seeing on your series on the bolt reinforcement. The freeze (Welch) plug is on the distributor (right) side of the engine. The bolt threads end on the carburetor (left) side of the engine. What fluid surrounds (outside of) the cylinder liners? If it is oil, then it appears that the engine has no water jacket on the carburetor side of the block. If water surrounds the cylinder sleeves, then one wonders about the space behind the Welch plug and the surface against which the bolt head seats. The bolt head is in the water jacket, right? Just trying to understand more about these engines. Thanks again.
Dick L
03-06-2001 11:26:57
 Re: Allis engine- Dick L? in reply to Bus Driver, 03-06-2001 09:51:03
third party image
Water flows around the cylinder sleeves. The chamber between the inner wall that the head of the bolt is seen, and the freeze plug is where the lifters and push rods work and the oil is returned from the oil filter to the front of the engine. The picture on the link shows the relationship of where the oil filter bolts on and to where the oil flows out behind the cam gear. The above picture just shows the opening more clear.
