SERIAL NUMBERS
John L.
03-06-2001 06:59:31
I recently purchased a Allis Chalmers tractor, but I'm not sure what year it is. The serial number on the back axle left hand side is WD 59775, the engine serial # is WD 265446 GA. If anyone can help me I would like to know the following:
1. what year is this tractor?
2. what horse power is this tractor and what does the GA stand for in the engine serial number?
3. at how many rpm should the pto run at?
4. how much pressure should the hydraulic pump put out ?
5. where would I find the hydraulic cylinders for the front end loader. I believe the front end loader is original equipment, however it is detached and the cylinders are missing. Even a measurement on the length and diameter of the cylinders would be of help.
Brian G.
03-06-2001 11:49:39
 Re: SERIAL NUMBERS in reply to John L., 03-06-2001 06:59:31
1. 1950
2. Belt: 34.63 HP,Drawbar: 30.23 HP GA=Gasoline
3. 548 @ 1,400 engine RPM
4. 3,300 to 3,700 P.S.I.
5. Don't know
