Hydraulic Tear down advice on the D17
Don Holden
03-05-2001 15:09:09
Well, thanks to Bill @ Sandy Lake Implement and Steve on the board I have removed the pin. Now the only Problem is I can't pop the housing off the transmission! Any suggestions will be greatly appreciated. I don't want to pound on it unless advised to do so by the experts. I have tried prying with a 4x4 to no avail. It is really tight!
Thank Again
Don Holden
steve
03-06-2001 16:22:00
 Re: Hydraulic Tear down advice on the D17 in reply to Don Holden, 03-05-2001 15:09:09
Left an answer on your previous message. Try a sharp chisle like a wood chisel or wedge and drive in at a corner into the gasket and pry it open. Might have to work in several spots untill you find an easier spot to get the chisel started. Dont beat so hard that you break off a corner, but you can hit it pretty good.
Don Holden
03-06-2001 17:51:31
 Re: Re: Hydraulic Tear down advice on the D17 in reply to steve, 03-06-2001 16:22:00
Steve thanks for the suggestion! I will give it a try along with some other ideas from folks familiar with the problem. I have tabled the project for a couple of days in order to get some other equipment up and running,but I will keep you posted on the results of the fix.
Don
