Operating pressure of C hydraulics
JW
02-28-2001 19:53:06
Does anyone know the operating pressure of the hydraulic unit on a '47 C? What's the most efficent size of cylinder to use with it? Thanks!
steve
03-01-2001 20:12:10
 Re: Operating pressure of C hydraulics in reply to JW, 02-28-2001 19:53:06
JW- Im not an expert and speaking from memory due to tractor not being here. My C had 2500 psi system. It has one small cylinder, maybe 1 or 1.25 inch bore. The cylinder is mounted under the seat and used to lift a belly mower or rear implement which dont weigh too much. The pumps on these tractors are very small volume, but lots of pressure. You can use a slightly bigger cylinder from Tractor Supply if you are looking for a new cylinder. Remember, small volume pump. Too big a cylinder and you will have slow lift, and may run out of oil to raise the mower. I would guess if you get to 2 inch bore you are getting too big. Newer tractors, D10 or 12 etc I believ drop to low pressure high volume.They may have 1500 psi, and have bigger cylinders to get the same lift force. hope this helps.
