Need cylinder numbers for `49 allis chalmers C
Tony
02-28-2001 13:21:09
she was sitting for 5 years and froze up i got it broke free and had all new valves, springs and guides and the head redone got good compression but i dont think its hitting on all 4. every few min. they all kick in only for a second or two then she sputters and bucks the carb was redone also that leads me to believe its electrical kinda like its cross firing with a wet cap or wires but they are fine and dry i have the firing order and point specs but dont know which cylinder is what any help would be great than you Tony
Barbara Burton
11-04-2001 08:14:46
 Re: need cylinder numbers for `49 allis chalmers C in reply to Tony, 02-28-2001 13:21:09
Need owners and service manual for a Allis Chalmers Model 310 with Kohler 10 HP motor. I think I have a 1965. It is in the 60's I think.
Dale E.
03-01-2001 06:10:36
Tony, If its 12-volt be sure you have a resitor in-line before the coil. To much juice will make it miss some. Make sure battery is fully charged. (Got a 6-volt one thats not charging.Think its because of to much paint and amp box not grounded and causing a no charge situation. When battery is charged up good the tractor doesn't miss. After a period of time it will start missing.) Also,some plugs seem to do better than others for me. Just somethings I've bumped into,good luck.
peterc
02-28-2001 17:09:46
cylinders are numbered from front to back 1 2 3 4 . to check for miss pull plug wires one at a time the one that makes no difference when removed is the dead cylinder.hope this is a help.
Tony
02-28-2001 17:43:50
 Re: Re: need cylinder numbers for `49 allis chalmers C in reply to peterc, 02-28-2001 17:09:46
hey thanks guys the cylinders were a little pitted but i ball honed them out and cleaned them up i should of thrown new rings in it got it really cheap has a huge mower deck with hydralics nice for the 15 acre yard lol
Dick L
02-28-2001 13:37:09
Take the spark plugs out and see what they look like directly after you shut her off. Tell us what they look like around the electrode. You may have a plug fouling out. Also get it running as slow as you can and pull one plug wire off at a time and see what ones make no difference in the sound of the engine.
