G. belt drive
Lowell
12-23-1998 09:42:17
I am new to the model G world and bought a 1950 with hydraulics installed. No belt pulley for power attachments like belly mower. Its my assumption! That pully is attached where the hyd. pump is now located. Can you have both?
Bob Semrau
12-23-1998 21:19:06
 Re: G. belt drive in reply to Lowell , 12-23-1998 09:42:17
Lowell :
My G has both - I don't think your combination is stock - I believe that you could get the belt pully without hydraulics, but not the reverse.
Maybe you just need to connect a pulley ?
On my G the belt pulley must be turning for the hydraulic pump to work.
Dusty
12-25-1998 17:44:20
 Re: Re: G. belt drive in reply to Bob Semrau, 12-23-1998 21:19:06
There is a cover plate that comes off and the pulley assembly installs there.
Go to a AGCO allis dealer and get a operators manual and a service manual. They do not cost much, and you will learn a lot about your G.
Good luck and have fun,
Dusty
larry parrack
10-18-2000 02:50:35
 Re: Re: Re: G. belt drive in reply to Dusty, 12-25-1998 17:44:20
trying to find a manual showing the hook up of the cutting deck&tiller on a allis_chalmers lawn tractor. model#B-210_serial#010667 THANKS/[email protected]
