G is only 36 inches wide?????????
James
02-20-2001 20:17:30
I just bought a G that is only 36 inches wide. My other one is almost 45 inches wide. What is the diference?
James
Gary Gilbert
02-21-2001 18:34:25
 Re: G is only 36 inches wide????????? in reply to James, 02-20-2001 20:17:30
The wheel tread of all G's is 36 to 64 inches, they are fully ajustable every 4 inches. To ajust the front wheels remove the bolts that hold the front axels and loosen the tie rods and slide then apart(not that easy if they haven't been moved for years). The back wheels are changed by changing the way that the centers bolt in or the way the center bends (in or out). To change the back wheels from 36 to 64 inches just put the wheels on the opposite sides of the tractor but keep the V mark pointing the right way. From (-) to )-(. This is to accomidate different implements and row spacings.
steve
02-21-2001 19:07:45
 Re: Re: G is only 36 inches wide????????? in reply to Gary Gilbert, 02-21-2001 18:34:25
yep, with the wheels/tires off, the axle shaft end to end should be same width on each tractor. all adjustement is in the wheel/rim combination mounting.
John C-IL
02-21-2001 06:08:49
James, where are you measuring? the wheels could be turned around or be different wheels.John
James
02-21-2001 06:18:23
 Re: Re: G is only 36 inches wide????????? in reply to John C-IL, 02-21-2001 06:08:49
John, the wheels are the same as on my other G. I am measuring across the rear wheels from outside to outside.
Thanks James
Rob on MO
02-21-2001 04:51:04
about 9 inches. sorry, couldn't resist! Maybe the smaller one was cut down for a specific application. Do they both have the same engine?
James
02-21-2001 05:32:32
 Re: Re: G is only 36 inches wide????????? in reply to Rob on MO, 02-21-2001 04:51:04
Rob, I knew it was coming!!!! Thanks. Yes the same engine.
Thanks James
