Starter Switch Connection
Allis In Chains
02-20-2001 18:37:10
I have a '49 C & just finshed rewiring it because it was not properly wired and lights/charging were not functional (typical problem!)All has been restored to original based on the diagram in my manual (same as the one posted here previously). The only snag is the starter. I have a small electrical component located next to the starter, just inside the tool area under the gas tank. The unit is about 1.5" in diameter and has a square base. It has two large terminals opposite each other, and one small terminal marked "S". I'm pretty sure it's not original to the tractor, but I will use it anyway because it worked before. It had the neg. cable to one side and the starter connected via cable to the other side. The question is - what connects to the small terminal? I've tried several combinations, but can't get the circut complete. I appreciate any help.
clickent
02-20-2001 19:14:17
 Re: Starter Switch Connection in reply to Allis In Chains, 02-20-2001 18:37:10
What you have is a starter relay that somebody has added on. The way it works is:
1) The the large terminals are power in from the battery and out to the starter. Doesn't matter which cable is hooked to which large terminal. These should be large cables as they have to handle large amp loads.
2) Inside is a electromagnet and large contacts.
3) The small terminal is for power in for the electromagnet. This circuit should be controlled by a switch that has to be held to stay on.
4) The idea is that you can control a large amount of amps remotely through a small switch. When you close the switch it energizes the electromagnet which closes the contacts and allows current to pass from one cable to the other.
You need to find the switch that was installed with the starter relay, probably on your control box on the steering post. Connect power to the switch and then from the switch to the small terminal. If it doesn't work then disconnect the large cables and try again. You should hear a click or clunk as the electromagnet slams the contact closed. If not check the mounting of the relay for a good ground. That's probably more than you needed but now you know. Good luck.
steve
02-20-2001 19:50:35
 Re: Re: Starter Switch Connection in reply to clickent, 02-20-2001 19:14:17
Agree. the original tractor had a 1/4 inch rod to the starter switch (mounted on the starter) that you push with your foot or hand to start. Somebody has installed a starter solenoid to start the tractor. Look for a push button on the column or steering wheel. Did they remove the switch and steel rod from the back of the starter??
