IB tractor design
steve
02-17-2001 19:11:09
I like the design of the Industrial B tractor, which is basically a "B" with the rear axle housings turned 90 degrees forward to lower the tractor 6 inches. My question is, has anyone ever tried to make one of these out of a normal B? Do you have to install a C-channel support from the axles housing to the front end for support like the original, or will the housing take the stress of mounting 90 degrees forward. third- how does the IB design work with a three point hitch and other chores around the farm? Is the back end to low or too light with the axle moved forward and up???
Chances R
02-18-2001 06:05:41
 Re: IB tractor design in reply to steve, 02-17-2001 19:11:09
I believe the first few IB's were made without the channel. I am thinking that the channel was placed on there to support (mount) mowers, blades, and to push from. Other than that I really cant help you.
Dick L
02-18-2001 06:35:20
 Re: Re: IB tractor design in reply to Chances R, 02-18-2001 06:05:41
They have a shorter torque tube as well, then several other things like the tank support and stearing. Saw a picture, and it might have been here, where the B front axle had been turned upside down and the axle housings turned. Makes an interesting looking tractor. Be fun to play with.
Ron
02-18-2001 11:45:36
 Re: Re: Re: IB tractor design in reply to Dick L, 02-18-2001 06:35:20
third party image
Here you Go
steve
02-18-2001 14:59:06
 Re: Re: Re: Re: IB tractor design in reply to Ron, 02-18-2001 11:45:36
Thanks for all the ideas and support. The "B" is a 1948 and has a wide adjustable width front end. I like the picture with the tube axle turned upside down, never thought of that. Does anyone have experience with using a three point setup, or center mower on a IB.
Dick L
02-18-2001 14:18:49
Yup, thats what I remembered.
Chances R
02-18-2001 14:00:57
Great picture!!
