NEED 5020 parts
Brad
12-22-1998 12:27:21
I have a AC5020 in need of various parts. RT. Frnt. axel housing, PTO parts, Frnt.Bucket cylinder
Stu Nicolai
01-21-2004 10:09:43
 Re: NEED 5020 parts in reply to Brad, 12-22-1998 12:27:21
I'm in the same boat - the bearings in my left front hub went out. I've sent out several inquiries to some websites for a complete used front axle, but no responses. It seems the 5020 is kind of a rare model. Have you found any sources for any front end parts? I have purchased a shop manual and I can fax you copies of any pages if you like. I'm looking for a parts manual so I can get the part numbers for the bearings, but they run about $40.
Denis Bourbonnais
09-12-2004 17:17:48
 Re: Re: NEED 5020 parts in reply to Stu Nicolai, 01-21-2004 10:09:43
Your nearest AGCO dealer should be able to get you the bearings. Or take the numbers - and the old ones - to a good bearings shop.
Casings are also available but expensive. Consider getting rebuilt at a good machine shop - a bit less expensive.
Redid both my front axles 2 years ago and everything works fine. Make sure you use 'locknut' liquid on all axle housing bolts. Make sure that you verify the axle to final drive housing free play - the big bolt on top of the final drive - frequently to make sure the seal there is tight.
Good luck.
Good Luck
