Wd or wd45
Dean Kyle
02-13-2001 19:05:24
I recently purchased a wd45 wd. the serial numbers on the left side of the rear end are AM 3835-7 0 4 the numbers on the block are IAM 8853-14
these numbers dont seem to match anything I see in the books .please help me out on this. I do know that it has a wd transmisson because of the straight shifter . thanks for your help.
John C-IL
02-13-2001 20:33:43
 Re: wd or wd45 in reply to Dean Kyle, 02-13-2001 19:05:24
Kyle, the numbers you are looking for are on a machined flat surface and are stamped. The engine number is on the left side of the block below the air cleaner and a little to the front. The tractor number is left of the diff. cover on the verical surface below the brake spring hole. John
