WD45 manifold crack
Farrell
02-13-2001 07:34:48
The manifold on my WD45 has a crack on the side against the engine. Have any of you had any luck in welding cracks? On the other hand, should I just bite the bullet and get a new one. Also the two outside ports are thinner on the outer edge than the interior ones.
Bus Driver
02-13-2001 09:55:47
 Re: WD45 manifold crack in reply to Farrell, 02-13-2001 07:34:48
I freely admit to having limited skills and experience in welding, but here is what worked for me on exhaust manifolds. I used non-machinable rods, which are steel and made for cast iron. They are the lowest cost rod made for cast iron. Built a big fire in the wood stove. Clamped the manifold to a 3/8 thick flat bar and heated the whole thing on top of the stove. Welded the manifold while still hot. Immediately removed the clamps and put the manifold into the stove. Let the fire die naturally and take the manifold out 2 days later. It worked well for me.
Farrell
02-20-2001 08:25:42
 Re: Re: WD45 manifold crack in reply to Bus Driver, 02-13-2001 09:55:47
Bus Driver,
Thanks for your message on repairing the manifold.
Farrell
Butch(OH)
02-13-2001 10:51:16
Sounds to me like you know more about the repair of cast iron than some of the "welders" I know.
