Alliis-Chalmers ModelB
Shawn
02-11-2001 21:42:25
Can someone please tell me GVW for 1949 model b allis-chalmers?
D13
02-12-2001 18:18:15
 Re: Alliis-Chalmers ModelB in reply to Shawn, 02-11-2001 21:42:25
The nominal weight for a B is right around 2050 pounds. Add some tire ballast, electric start(starter, generator, and battery), wheel weights, side weights, a full tank of gas, belt/pto/hydraulic unit, and that belly mounted mower and you can push it up to 3000 lbs pretty easily. I don't drive mine on my engineered septic (compresses the sand and leaves ruts). It will rut a wet clay lawn even with no weights and the mower floating on its own.
Dick L
02-12-2001 04:04:25
somewhere under 2500 lbs normally.
