D17 generator conversion
george
02-09-2001 17:03:47
I have a 1963 D17 gas with a 12v positive ground& generator.I would like to change it over to a 12v alternator neg grnd.Can anyone tell me what alt.I can use and if I can still use the existing mount with it? Do I have to do major modifications to adapt this over(wiring,distb.,starter etc? Any info would really help Thanks
steve
02-10-2001 07:38:25
 Re: D17 generator conversion in reply to george, 02-09-2001 17:03:47
third party image
The delco 10SI is a common choice. Go to Auto Zone for $35. They came on mid 1970's Chevrolet. There is a 1/4 inch positive batter terminal on the back and two spade connectors on the side. You can buy a special twin spade connector for this. The number tow or "F" terminal has 12 volts all the time. The no 1 or "R" terminal is the resistor terminal. NOrmally this is connected to the idiot lite on a car. On a singelwire system you can put a diode in this line and connect to the 12 volt terminal so volts can flow from the alternator to the battery, but not the other way and drain the battery. I believe a better way is to get a large resistor, 10 ohm, 10 watt from radio shack for $2. it is brown and 1/2 by 1/2 by 3 inches long. The resistor drops voltage slightly and makes the alternator charge at lower engine speed. It must be connected to a terminal on the key switch so you can cut the circuit when not running, or battery will drain backwards. Just reverse the terminals on the battery and amp meter and you are ready to go. Some people reverse the wires on the coil. Its a good idea, but dont seem to make any difference. The starter and ignition (coil and point) dont realy care. The lower bracket to mount the alternator will work. You need to modify the upper bracket or make a new strap. Pulley will come with the new alternator.
george
02-10-2001 13:15:41
 Re: Re: D17 generator conversion in reply to steve, 02-10-2001 07:38:25
Thanks for the information on how to do the whole complete job Steve.It looks as it can be pretty simple.I know what I'll be doing tommorrow. Thanks again
steve
02-10-2001 19:01:54
 Re: Re: Re: D17 generator conversion in reply to george, 02-10-2001 13:15:41
make sure you get the delco with the internal regulator built after 1973, you can tell by the two spade connectors being in line. The external type had two spade connectors side by side.
