WD45 carb
JJW
02-08-2001 06:00:29
I have frost that forms on the outside of the carb while it's running . What is the correction for this ??
Bryan IA
02-09-2001 13:03:08
 Re: WD45 carb in reply to JJW, 02-08-2001 06:00:29
Mine also did the same. I rebuilt it and made shure breather clamps were tight and it quit frosting up.
Tom
02-08-2001 18:05:19
warm weather/spring
Mac
02-08-2001 06:44:40
Mine does that too, but leaves after the engine gets up temperature
Dave Grubb
02-09-2001 14:35:56
 Re: Re: WD45 carb in reply to Mac, 02-08-2001 06:44:40
This is a normal happening for a naturally aspirated carburator engine. It is called carb icing in the world of aviation and caused many crashes until it was understood. Piston powered normally aspirated aircraft engines control the incoming air temperature to a point above which the icing will occur.
